[CG522-E] PIN code configuration
david-610
Community Member
I am testing Cellular Gateway 5G (CG522-E) with a 5G SIM card that need a PIN code.
How can I configure the PIN code of the SIM card on the CG522-E ?
The online configuration documentation for CG522-E is light and I cannot find this information.
Best Regards
David
Rich R
Thanks good to know.
So then your only option is to put the SIM in a phone or something else where you can turn off the PIN and then put the SIM back in the gateway.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
5 Replies 5
Rich R
Try looking for commands similar to older products & IOS:
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/4GLTENIM_SW.html#pgfId-1333566
cellular unit lte sim { lock | unlock } pin
cellular unit lte sim change-pin pin new-pin
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x/cisco_1100_series_swcfg_chapter_01011.html
cellular slots subslots interface lte sim change-pin current-pin new-pin
cellular unit lte sim {lock | unlock } pin
david-610
Community Member
Thank rrundlig for your help but the CLI of the Cellular Gateway is quite different than other LTE devices (NIM on ISR4K or ISR1K).
CellularGateway# cellular 1 ?
Possible completions:
firmware-activate modem-at-commands modem-radio-reset
modem-reset upgrade
Then you might be able to do it using modem AT commands since that is one of the options you have.  It's going back a long way but they were commonly used when the GSM standard first emerged.
Try those suggested at: https://iot-developer.thalesgroup.com/threads/unlock-sim-require-pin-code
"You use AT command AT+CPIN.
AT+CPIN=<code>
you can also use AT commands to disable pin usage. Most SIM cards support this
at+cpin?
+CPIN: READY //enter SIM PIN
OK
at+clck="SC",2
+CLCK: 1 //query SIM PIN status 0 = sim pin disabled
OK
at+clck="SC",0,"1111" //disable sim pin usage
OK"
david-610
Community Member
Thanks again rrudling.
The AT command AT+CPIN="pin-code" is correctly accepted but the SIM card status stays in "pin sim" status.
According Cisco, the PIN code configuration is not possible today on the Cellular Gateway and will be available in a future release.
Rich R
