07-19-2023 05:08 AM
Hi everybody
APs appear as not Joined after deleting the controller hostname. I also removed crypto with the CLi command "no crypto pki trustpoint C9800_WLC_TP."
I then recreated the certificate with " C9800_1E #wireless config vwlc-ssc key-size 2048 signature-algo sha256 password zero xxxxxxxxxx"
Here is what I am getting: Configuring vWLC-SSC...
Script is completed
Now it appears as if I have two certificates the created earlier on the one created recently.
And my APs are no longer joining the controller.
C9800_1E##sh wireless management trustp
Trustpoint Name : eWLC1_WLC_TP
Certificate Info : Not Available
Private key Info : Not Available
FIPS suitability : Not Applicable
C9800_1E#
Jason
07-19-2023 05:40 AM - edited 07-19-2023 05:40 AM
- Have a checkup review of the controller configuration with the CLI command : show tech wireless , feed the output into :
https://cway.cisco.com/wireless-config-analyzer/
It is highly likely that the current configuration issue and or fault will be pointed out immediately ,
M.
07-19-2023 05:43 AM
Hi @marce1000
Thank you I will try that!
08-05-2023 08:08 AM
Have you carefully followed the guide?
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/trustpoints/b-configuring-trustpoints-on-cisco-catalyst-9800-series-controllers/c-workflow-to-configure-a-trustpoint-for-a-self-signed-certificate-on-catalyst-9800-cl.html
no crypto pki server WLC_CA
no crypto pki trustpoint "<hostname>_WLC_TP"
wireless config vwlc-ssc key-size 2048 signature-algo sha256 password 0 <password>
