Changing select AP TX Power Level
declan liddy
Frequent Visitor
Frequent Visitor
Hi I have some Access Points that have left holes in the coverage, this is mainly on the 2.4 ghz if i change manually change the power levels on these will it affect the power levels of other Access Points that have their power set Globally and cause other problems
patoberli
Short answer, if TPC is enabled, then Yes it will affect the other APs and cause problems.
Have you done a wireless survey before installing the APs?
If TPC is enabled, what have you set as Power Threshold and Minimum / Maximum Power Level Assignment?
Do not change those settings before reading about what they do.
Hi I am not where I can look at the TPC setting, it would be what is set out of the box.
There was a certification performed, the 5ghz was fine but some areas the 2.4 was out of -67 scope.
So the controller does not differentiate if power is manually set or global it will adjust the globally set access points as needed
Do you use voice over Wi-Fi services? Otherwise -67 is not really required for a stable signal. But I suggest to have at least -72 dBi at the outer regions of a cell where a person should have a good signal.
You find the TPC settings on the WLC under Wireless - 802.11b/g/n (or a/n/ac) - RRM - TPC.
What are your current settings there?
ammahend
how did you determine that there is a coverage hole at 2.4 GHz ?
-hope this helps-
