Channel & Power Issues
Craig Le-Butt
Level 4
Level 4
HI
I'm led to believe that the WCS controls the Channel and power issue for the APS.
We are using image
WCS      5.2.1.148
WiSMs – 5.2.193
Triangulated coverage.
Several APs are using the same channel over lapping each other and using TX Power 1 when they are with in 15 meters of each other.
This is in open ward areas.
Shouldn’t the controllers or the WCS be adjusting this automatically?
Rob Huffman
Hi Craig,
The control you are referring to is called RRM or Radio Resource Management.
This excellent RRM doc cleared up alot of questions for me,  it used to be the case that
any AP needed to hear at least 2 neighbor AP's for RRM to kick in. This may be the case
in your example;
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml#dcaa
Hope this helps!
Rob
Hi Rob
Thanks for the link.
I ran though and the settings look correct, but we still have the same problem.  APs using Full Power and using the same channels as surrounfing APs.
We are using Ekahau to messure the interferance and changed the AP channel on the Ekahau to see what the effects would be, straight away this has decreased by 98%
Cheers
Craig
George Stefanick
To add to Rob's comment...
RRM is not handled by WCS, rather it resides in the controller. Make sure you dont have a RF leader issue and is your controllers in the same RF domain ?
