Showing results forĀ
Search instead forĀ
Did you mean:Ā
characteristics of wireless repeater topology
mahesh18
Level 6
Level 6
Hi all,
I was studying for exam and i found this topic
characteristics of wireless repeater topology--
it says Autonomous access points are required.
is this true can we also use lightweight AP  with repeaters?
second it says that  The SSID of the root access point must be configured on the repeater  access point.
IF someone can explain me this in more detail please?
thanks
mahesh
Surendra BG
Q>>  it says Autonomous access points are required. is this true can we also use lightweight AP  with repeaters?
ANS - Repeater is supported only on Autonomous AP design.. In MESH design we do use repeater term but its different compared to the REPEATER what you are pointing to..
Q>> second it says that  The SSID of the root access point must be configured on the repeater  access point.
ANS - To get the REPEATER AP associate with the ROOT AP, we need to configure both the APs for identical settings apart from the IP and the Station role.. so that they will associate. If different SSIDs are configured the APs will not associate.
Lemme know if this answered your question..
Surendra
Surendra BG
Surendra BG
Surendra
Surendra BG
Hi Surendra,
Many thanks for the reply.
You answered my both questions.
reagrds
mahehs
