Can someone tell me how I can bridge multiple access points with the same SSID? I have 5000sqft of space that I need to install. Will multiple Cisco 1100 be sufficient or I need to move up to higher end products.
I would suggest using a AP1200 series product so you can have option to use different antennas. The AP1100 has a fixed antenna and may not be able to provide sufficient coverage. Hope this helps.
Aaron
Learn, share, save
