Cisco 1200 AP print issue
a.mir
We have a Cisco AP 1200 that has been configured with the standard config. Users have no issues authenticating and associating with the AP, however, they can't seem to print from it. They can print with a wired connection and I can ping the printer from the AP. Can you anyone pls help?
Thanks.
scottmac
Level 10
Level 10
Check your AP and see if PSPF (Public Secure Packet Forwarding) is turned on.
PSPF prevents a user on the system from directly connecting to / talking to another user on the system.
You didn't mention if the printer itself was wired or wireless ...
Good Luck
Scott
