There is a list of A radio channels and what power settings can be used for the particular channel you are using.
from Cisco-
The maximum legal transmit power is greater for some 5-GHz channels than for others. When it randomly selects a 5-GHz channel on which power is restricted, the access point automatically reduces transmit power to comply with power limits for that channel.
