dear all , have a good day,,,
i have issue with Cisco AP 1240 , below mention text,ethernet port hardware ,,,,how to fix
ap: Xmodem file system is available.
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 1536
flashfs[0]: Bytes available: 15997440
flashfs[0]: flashfs fsck took 22 seconds.
Base ethernet MAC Address: d4:8c:b5:4b:63:86
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
ether_init
tftp_init
boot
button is pressed, wait for button to be released...
button pressed for 68 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
