Wifi Roaming on Home Network
imranasif
Here is the setup.
Router is Cisco 837 with active gateway and DHCP configured. 2 linksys access points and one D-link connected to the switch ports and DHCP is disables on all of them. All the APs have same SSID and password encryption etc. Will I be able to roam on WiFi network.
Imran
Rasika Nayanajith
Hi Imran,
If it is different vendor AP, I am not sure.  You have to give it a try & see what is the behavior.
If it is Cisco AP (configured with PSK) then roaming will work in the given scenario.
Rasika
*** Pls rate all useful responses***
Hi Imran,
in addition to Rasika I'd like to metion that is maybe a good idea to test every AP first but shutdown all others to make sure that they are working fine. When so, I would say from the theoretical perspective it should work whe the RF design allows that. So that the signals are good enough or bad enough for roaming. I mean the current connected AP is seen at the "new" location bad enough to let the client roam to a better AP.
regards,
Sebastian
