Cisco 1560 E Bridge-Access Point - Antenna Setup
michaelgitonga
I am designing a Cisco WLAN MESH bridging solution using Cisco 1560E Access Point/Bridge. Is it possible to use the following antennae setup?
  1. Top Ports Single Band 5GHz antennae using AIR-ANT5114P2M-N= (5 GHz 14 dBi Directional Antenna , 2 port , N connectors)
  2. Bottom Ports Dual Band 2.4GHz antennae using AIR-ANT2547VG-N (2.4 GHz 4dBi/5 GHz 7dBi Dual Band Omni Ant., Gray, N conn.)
Specifically, is it possible to use Single Band 5GHz directional antenna AND Dual Band 2.4GHz/5GHz Omni antennae in the same 1560 AP through software control/software switch?
0 Replies 0
