12-16-2020 08:25 AM - edited 07-05-2021 12:55 PM
I have 2 cisco 1562D Aps that i am configuring as a remote bridge with one AP being the RAP and ME controller and the other being a MAP. They are both running 8.10.142 code, i have Ethernet bridging enabled and when i got to edit the gigabit interface Ethernet 0 to change it from access to trunk it says that the AP has trunking disabled. Is there a way through the CLI or mobility express to enable this feature at the AP level?
Solved! Go to Solution.
12-16-2020 09:44 AM
I actually ended up tracking it down. I had to go into the CLI for the controller and throwing this command in:
config ap vlan-trunking enable ap-name
12-16-2020 09:42 AM
- Check if these info's can be helpful :
M.
12-16-2020 09:44 AM
12-16-2020 10:23 AM
Great job posting the solution! Makes it easy for others in the future to quickly find answers.
