Cisco 1572 AP Tx Power Levels
Brett Verney
Hi there,
Does anybody know what the available Tx power levels are on the Cisco 1572 APs? I believe the APs maximum Tx power level is the legal limit of the regulatory domain, but I am more interested in what the levels are on the lower end of the scale. Unfortunately I don't have one available to test.
Brett
Rasika Nayanajith
Hi Brett,
I think you are looking for these values.
http://www.cisco.com/c/en/us/td/docs/wireless/compliance/reference/guide/1570_EU.html#55419
Also refer this link if you require more details on AP technical spec
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1570/installation/guide/1570hig/1570_axa.html
Rasika
*** Pls rate all useful responses ****
Rasika Nayanajith
Hi Brett,
Rasika
Hi rasika,
Are these values based on an AP 1572 withtout any antennas ?
I would like to calculate the EIRP of a AP1572 with AIR-ANT2568VG-N antennas.
I have to calculate the AP transmit power + the antenna's gain
But is the AP transmit power related to the table you posted ?
I mean, if I use power level 1, should I consider :
For 2.4 GHz : 15 + 8 (gain) = 23 dBm ?
AL
