Cisco 1815w Lan Port Problem
Aquiles
I have a cisco 1815w, i have enable the lan port, but when i connect a printer ticket,  the leds from the printer and ports are flashing, but  have not conectivity,  and on the controller running 8.10.190, but if i connect another thing like phone, camera or desktop, it work, the printer ticket has static ip, if i connect the printer to the switch it works, what could be happening.
marce1000
 - Checkout : https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-7/config-guide/b_cg87/ap_power_and_lan_connections.html#converting-aux-to-lan-port
 M.
Rich R
Upgrade to 8.10.196.0 as per TAC recommended (link below) to eliminate known bugs
Also check out https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/global_traffic_forwarding_configurations.html#passive-clients
thanks for the info rich, i already upgrade to 196, but i still have the problem, its actually what it says about pasive clients dont sending info, the wireless controller act as arp proxi so, how can i disable that, i didnt find how to fix this yet thank u for the info
Did you read the link I provided?  You need to configure passive client.
