Cisco 1852i continue to lost and rejoin to Mobility Express
thomas546
Dear all,
I met one problem when testing Cisco 1852i with Mobility Express.
There're two 1852i called AP1 and AP2.
AP1 is running Mobility Express and AP roles. AP2 is only AP role.
At first, everything is OK, but I find AP2 could not contact to ME , then run DISCOVER process, and rejoin to ME again.
Lost and rejoin processions happen frequently,  AP2's log is as following.
AP1 and AP2 are connecting to stacking L2 switches, power are from PoE injectors.
I changed ME role to AP2 to try, but AP1's lost and rejoin happened again.
Thomas
AP2's Log
[*09/13/2016 13:48:03.8363] Re-Tx Count=11, Max Re-Tx Value=10, NumofPendingMsgs=8
[*09/13/2016 13:48:06.6854] Re-Tx Count=12, Max Re-Tx Value=10, NumofPendingMsgs=8
[*09/13/2016 13:48:09.5345] Re-Tx Count=13, Max Re-Tx Value=10, NumofPendingMsgs=8
[*09/13/2016 13:48:12.3936] Re-Tx Count=14, Max Re-Tx Value=10, NumofPendingMsgs=8
[*09/13/2016 13:48:15.2427] Re-Tx Count=15, Max Re-Tx Value=10, NumofPendingMsgs=8
[*09/13/2016 13:48:18.0918] Re-Tx Count=16, Max Re-Tx Value=10, NumofPendingMsgs=9
[*09/13/2016 13:48:18.0918] Max retransmission count exceeded going back to DISCOVER mode.
[*09/13/2016 13:48:18.0918] GOING BACK TO DISCOVER MODE
ME's Log
Tue Sep 13 21:48:42 2016;10.8.8.58; <131>MMGSHWLC: *spamApTask0: Sep 13 21:48:42.644: %LWAPP-3-RD_ERR9: spam_lrad.c:12482 APs 80:e8:6f:d3:87:c0 country code changed from (UX) to (CN )
Tue Sep 13 21:48:42 2016;10.8.8.58; <131>MMGSHWLC: *spamApTask0: Sep 13 21:48:42.852: %LOG-3-Q_IND: spam_lrad.c:12482 APs 80:e8:6f:d3:87:c0 country code changed from (UX) to (CN )
Tue Sep 13 21:48:42 2016;10.8.8.58; <131>MMGSHWLC: *spamApTask0: Sep 13 21:48:42.852: %CAPWAP-3-AP_AUTOCONVERT_ERR: capwap_ac_sm.c:3579 The system is unable to autoconvert AP  80:e8:6f:d3:87:c0 to supported mode.
Tue Sep 13 21:48:42 2016;10.8.8.58; <131>MMGSHWLC: *spamApTask0: Sep 13 21:48:42.920: %CAPWAP-3-MDNS_INIT_NOT_DONE: capwap_ac_sm.c:7911 mDNS module is not initialized yet, but a mDNS AP : 80:e8:6f:d3:87:c0 has joined.Aggregated query is not sent until mDNS init.
thomas546
Dear all,
After discuss with TAC, the problem was resolved.
1, Update to 8.2.130.0
2, Configure ME ip address on all APs manually
capwap ap primary-base <Primary-WLC-sysname> <Primary-WLC-IP address>
3, Disable AVC function
config flexconnect group <group-name> avc <wlan-id> visibility disable
Thomas
nikhil.kapure
Dear all,
1, Update to 8.2.145.44
Thomas
Why not upgrade to 8.2.130.0 since that was the solution from the other user on this thread. I'm not a fan of escalation images.
-Scott
-Scott
