08-19-2011 10:49 AM - edited 07-03-2021 08:36 PM
Hi all,
I have here in the work a wireless lan controller and 4 access points in the network. Everything was working fine until yesterday ( and I don´t know why...)
The leds of the ports of the controller are blinking and the status led is blinking and orange.
The problems remains If i reboot the equipment.
If I connect to the console port the following appears:
Anyone knows what is the problem? What's happen?
What is the solution?
Best regards
Milton Aguiar
08-19-2011 03:42 PM
Hi Milton,
An Amber/Orange Status LED indicates a failure on boot of the 2100 WLC:
http://www.cisco.com/en/US/docs/wireless/controller/2100/quick/guide/ctrl206q.html#wp39363
If the unit is responding properly to console, it's possible we could recover it. However, that output does not look promising. Also double check that your serial settings are correct :
•9600 baud
•8 data bits
•No flow control
•1 stop bit
•No parity
If the console is not responsive, we're looking at a hardware failure and you should contact the TAC.
-Patrick Croak
Wireless TAC
08-22-2011 02:26 AM
I think you're right. The problem must be a hardware failure.. I will contact the TAC
Thanks for your help.
Milton Aguiar
