Cisco 2500 WLC with Wndows 2019 NPA?
Wasserflo
Hi, we have a 2500 WLC here and it's still working with a Windows 2008 NPA and the AD username/pw.
I want the NPA now moved to a new 2019 server. I have exported the config and imported into the 2019.
I have added the new server as Radius server in the 2500. Ping from here works.
But I can't connect to the network. The Eventlog says:
(It's from a german server, so here is the original, followed by my translation)
Der Client konnte nicht authentifiziert werden, da der angegebene EAP (Extensible Authentication-Protokoll)-Typ vom Server nicht verarbeitet werden kann.
The client can't be authenticated, because the EAP type can not be processed from the server.
Any thing I can do here to make it work with 2019?
Cheers
Florian
It's working now.
The solution was to install a client certificate on the new installed server.
you can enable more EAP types in your NPS policies and check. also check below thread, that will give some insight about another eap issue
https://community.cisco.com/t5/wireless/wlc-nps-eap-tls-machine-certificate/td-p/3913871
Good luck
KB
It's working now.
