04-22-2015 08:16 AM - edited 07-05-2021 02:59 AM
Hi there! The Cisco AIR-ANT2524V4C-R antenna comes with a standard 3 ft (91.4 cm) plenum rated, UV stable cable. Is there a possibility to extend this cables?
We have a building there is no room to place the accesspoint near the external antenna.
But there is a possibility around 30ft / 10m distance from the antenna for the accesspoint.
any ideas?
Best Regards
Andri
04-25-2015 04:25 PM
Cisco makes antenna cables which you can use for this, where in this case you need four of them with "RP-TNC" connectors. Keep in mind that how longer the cable, the more loss you will run into. This antenna does not have a lot of gain, which does not give you a lot of room for raising the TX power on the access-point to compensate for the cable loss (because the chance is you already had it on the maximum).
I advice you to manually calculate the EIRP to check if the solution does still meet your requirements. See for more information and product numbers this link.
04-29-2015 03:15 AM
Whenever practical/possible, please keep antenna cable runs as short as possible. Cisco offers low loss (LL) and ultra low loss (ULL) cables, which have the same characteristics as Times Microwave LMR-400 and LMR-600.
Cisco cables carry the part number AIR-CAB (Aironet Cable) and then a length. For example, a 20 Ft length of LL cable with RP-TNC connector is Cisco AIR-CAB-020LL-R. These heavy black cables are not Plenum rated and are primarily for outdoor use or manufacturing areas.
