Cisco 2800 AIR-AP2802I-A-K9 use in standalone mode as a controller and access point multiple ssid see other arp request
samir_1976
Hi All,
I am using Cisco 2800 AIR-AP2802I-A-K9 use in standalone mode as a controller and access point. I have created
3 ssid on it. My problem is test1 ssid broadcast arp request is seeing on test2 ssid.
Is there any way to disable this.
Thank you all in advance
5 Replies 5
patoberli
Are the two SSID attached to the same VLAN?
What software version are you running on the AP/ME?
Both SSID on different VLAN and software version 8.5.140.0
Interesting, could you create a pcap on both testclients and upload it here with the ARP packages in it?
FYI,
It was bug in Cisco 2800 as per the think link.
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-3800-series-access-points/214491-arp-responses-for-default-gateway-ip-add.html
We upgrade our software from 8.5.140.0 to 8.5.151.0 and it resolved the issue
Thanks for posting the solution.
