I have a single Cisco 3800 running Mobility Express. Unfortunately, I have been trying to set it up with 160 or 80+80 but it gives an error "unable to assign IPAddress" and then all radios shut off and then I have to turn them back on manually. I have received another error "The DCA selected channels do not support this". Is there something specific that I need to configure in order to get 160Mhz support? I have already selected 1 channel per 8 channels so it can combine to give the 160MHZ bandwidth.
Hoping someone has already done this and can help out.
Solved! Go to Solution.
Thank you Scott. That would explain it why it doesn't work and the whole AP behaves weirdly. I guess Mobility Express still is a long way from a complete solution and controller is the way to go even for a small solution.
Thanks again Scott.
