Cisco AIR-AP1852 Failing to Join Controller
Mohamed.Ashraf
[*02/02/2020 16:27:41.4927] CAPWAP State: Discovery
[*02/02/2020 16:27:41.4927] IP DNS query for CISCO-CAPWAP-CONTROLLER.FarmFritesEgypt.com
[*02/02/2020 16:27:41.4927] DNS resolved CISCO-CAPWAP-CONTROLLER.FarmFritesEgypt.com
[*02/02/2020 16:27:41.4927] DNS discover IP addr: 10.11.100.100
[*02/02/2020 16:27:41.4927] Discovery Request sent to 10.11.100.100, discovery type DNS(3)
[*02/02/2020 16:27:41.4927] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*02/02/2020 16:27:41.4927] Discovery Response from 10.11.100.100
[*02/02/2020 16:27:41.4927] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*02/02/2020 16:27:41.4927] Failed to decode discovery response(status = 4).
[*02/02/2020 16:27:41.4927] CAPWAP SM handler: Failed to process message type 2 state 2.
[*02/02/2020 16:27:41.4927] Failed to handle capwap control message from controller - status 4
[*02/02/2020 16:27:41.4927] Failed to process unencrypted capwap packet 0x225a000 from 10.11.100.100
[*02/02/2020 16:27:41.4927] Failed to send message to CAPWAP state machine, msgId 0
[*02/02/2020 16:27:41.4927] Failed to send capwap message 0 to the state machine. Packet already freed.
[*02/02/2020 16:27:41.4927] IPv4 wtpProcessPacketFromSocket returned 4
[*02/02/2020 16:27:41.4927] Failed to process unencrypted capwap packet 0x2260000 from 10.11.100.100
Note :
Access points worked fine before for along time but this issue happened at 4 access points early
Time with Access point is different with time at WLC
5 Replies 5
silvio.lui
Sounds like no comunication between the AP and WLC, as no CAPWAP response after broadcast requirement .  If the WLC was not changed the firmware version (please ensure, because it would get incompatible SW), you could try it:
1- Ensure the WLC country is compatible with the AP domain
2 -Use the DHCP Option 43 to send the IP in Hex. to the AP
   to one WLC = f104.<AAAA:BBBB:CCCC:DDDD>
   for two WLC = f108.<AAAA:BBBB:CCCC:DDD>
Silvio Silva
Mark Elsen
 - Check wireless/controller/software versions compatibility requirements :
                              Wireless compatibility matrix
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mohamed.Ashraf
Access points worked fine for along time berfore but this issue happened soon without any changes at WLC and access point.
 - Make sure , time settings are correct and synchronized on all involved devices (controller + ap) - preferably use an NTP server (service). Also make sure that the Regulatory Domain settings on the controller are still valid and or aligned with the ap-models being used.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Mohamed.Ashraf
There are access points same model and Regular domain working now, This Issue happened for 5 access points
