Cisco 3802i is not showing up on PI 3.0.3
Ramon2229
Cisco 3802i is not showing up on PI 3.0.3 is it supported on this version of Prime if not what version supports them.
3 Accepted Solutions
Rasika Nayanajith
Refer below for the compatibility matrix
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148422
I would try this with PI 3.1
Rasika
*** Pls rate all useful responses ***
JEFFREY SESSLER
You'll want to be on Prime 3.1 MR1 - MR1 gives you access to XOR radio features.
Jeff
mohanak
To support 3800 series you need to be on Prime 3.1 or 3.0 Technology Package. 3800 supports from 8.2 version of wlc .
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148410
Rasika Nayanajith
Rasika
JEFFREY SESSLER
Jeff
mohanak
