2702I not connect to WLC
Eric Kemsley
I have a 2504 WLC that I have 1042 and 1602 AP's connected to already and working great. I purchased some AIR-CAP2702i-A-K9 AP's. When i connect the new 2702 AP to the network, it is not connecting to the controller. It just flashes Red and Green.
%LWAPP-4-Client Event log: Invoking capwap discovery
Could not discover WLC
I have licensing for 71 AP's and have 50 AP's connected now.
The 2702 has version (AP3G2-Boot-M) 15.3(3)JC ,Release software (fc2)
Loader version 15.2(4)JB5m Release Software (fc2)
Image file ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx
The2504 controller is running version 7.4.100.0
Leo Laohoo
The 2504 controller is running version 7.4.100.0
The controller needs firmware upgrade to, a minimum of, 7.6.120.X to support AP2700.  Read HERE.
6 Replies 6
Leo Laohoo
Thank you for the answers.
The firmware goes from 7.4.140 to 8.0.133. There is no 7.6.120. Will my older AP's work with the 8.0.133 without issues?
TIA
What are the "old APs"?  The Release Notes will specify what APs are supported and what aren't.
Supported AP models in 8.0.133
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148410
8.0.133.0
15.3(3)JA8/
12.4(25e)JAP8
Lightweight APs: 1040, 1130, 1140, 1240, 1250, 1260, 1600, 1700, 2600, 2700, 3500e, 3500i, 3500p, 3600e, 3600i, 3600p, 3702e, 3702i, 3702p, 600 OEAP, 700, 700W, AP801, and AP802
Outdoor and Industrial APs: 1522, 1524PS, 1524SB, 1532E, 1532I, 1552E, 1552H, 1552I, 1552C, 1552EU, 1552CU, 1552S, 1570, and IW3702
mohanak
Minimum version to support 2700 is 7.6.120.0.
Refer compatibility matrix : http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-147162
informatyka5
Hi.
I had similar problem with 2702 APs.
Try to put AP ip onto DHCP server ( ip u will use in future for it).
Now leave it connected , with "flashing lights" for about 20-30 mins.After about 30 min try to discover AP on ur WLC.
