Cisco 4402 not showing link
pcarideo
I am installing a Cisco 4402. The port 1 and port 2 link lights will not come up. We tried using fiber and copper GBIC's, but the link will not establish. We made sure the ports we active. Am I missing a simple problem?
svanguilder
Make sure your VLAN setting are the same on the WLC and the switch. I had issues like that when I first set our WLC up. But I can't remember if there was a link light or not before it started talking.
I checked the VLAN configs on the 4402 and the switch, both are set to trunk. The customer is using non-Cisco sfp GBIC's. Could this be the problem? Is there a list of supported GBIC's for the 4400 series controller?
I would use a Cisco GBIC. Here is what I wound up having to set the switch port on our Core Switch to so it would connect to the WLC:
interface GigabitEthernet6/45
description trunk port to Cisco WLC
switchport trunk allowed vlan 1-25
switchport mode trunk
Not sure if that helps or not.
