06-01-2016 02:51 AM - edited 07-05-2021 05:09 AM
I have installed a 5508 WLC running version 7.0.220.0 and set it up as a Guest Anchor. The customer wants to install a SHA 2 SSL certificate. Do I need to upgrade the code to do this and if so to what version?
06-01-2016 08:50 PM
You have to upgrade to AireOS 8.0.x or above.
I would suggest go with 8.0.MR3 code given below
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80mr3.html
Check your AP model & its compatibility
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
Rasika
*** Pls rate all useful responses ***
06-10-2016 07:06 AM
Thanks for the response, though I have found that SHA2 can go on a WLC running 7.3.101, I've tried it and it works.
06-10-2016 05:28 PM
I was going to say I think I have SHA2 working on 7.6.
06-02-2016 08:49 PM
The WLC supports SHA-2 certificates since release 8.0.100, check the compatibility of access points with IOS version support and 8.0.133 is TAC recommended version.
