Cisco 5520 Wireless Lan Controller bulk removal/disconnect devices
graham.jomyron
I was looking for a way to remove multiple devices via device type or some other filter.  I can, for example, see that there are 300+ iphones on an ssid that they should not be on. What would I need to do to create a policy that doesn't allow iphones to connect to the Access points, or something similar to that affect.  Either that or is there a way I can bulk remove/disconnect client devices.  I'm able to filter via ssid and device type to see all of the iphones connected to the ssid, but I have to currently remove/disconnect them one at a time.
Arshad Safrulla
You have to enable DHCP and HTTP profiling, then use a local policy to block the devices as required.
You can follow the below guide.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/NativeProfiling75.html
Or if you are using DOT1X, you need to enable profiling at Radius server and implement block policies there accordingly.
Arshad Safrulla
  1. I appreciate the information.  I'll give it a shot then let you know how it goes
