AIR-AP1832I-K-K9 no power supply with AIR-PWRINJ6
JunHeng
My AP (AIR-AP1832I-K-K9) can be turn on with PoE but not the Power Injector (AIR-PWRINJ6).
If anyone please can help me with my case then it will be highly appreciable.
Thank you,
JunHeng
according to datasheet,
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1830-series-access-points/datasheet-c78-735582.html
this support both J5 and J6 injectors with conditions. better check device with another power injector because port may be faulty. also make sure you are connecting to correct power in-out ports to AP and switch. also check power source connected to injector.
rate this and mark as answer, if this solved your issue
Good luck
KB
Hi Kasun,
Thanks for replying,
I’ve tried different APs with the same injector, they all works, it’s just this AP has some power issues. The injector is working well.
Thank you, Regards,
JunHeng
in that case, better open TAC and request for replace.
rate this and mark as answer, if this helps
Good luck
KB
