02-08-2011 03:31 PM - edited 07-03-2021 07:47 PM
I've tried setting up my Cisco 7920 on my wireless network. However it keeps sitting at Authenticating with AP. I'm using the configuration utility and running it through the wizard but have had no luck. I'd like to at least get it to work with WAP instead of WEP. Does anyone have experience with this who can provide step by step directions? I've looked at directions and read the manual but no luck.
Thanks!
02-08-2011 10:54 PM
Of course.. Can you provide more information..
What security protocol do you plan to use
What type of wireless network do you have
for starters ...
02-08-2011 11:12 PM
Hi as mentioned id like to use WPA. I'm using an Actiontech Router supplied by verizon which supports B/G. I've run through the wizard selected WPA ASCII and entered my password then selected AKS for encryption. Left WEP to none.
So I can't seem to get any mixture to work
Sent from my iPhone
02-08-2011 11:20 PM
Actually your original e-mail states WAP, I assumed you meant WPA, but wanted to double check. What is AKS? WPA uses TKIP for encryption... Also do you have a Call Manager?
02-09-2011 09:28 AM
Sorry about that, mistyped it in my first post. Also meant to say AKM I was responding late at night. When I select WPA it requires me to select AKM. Here's a screen shot of the config once I run through the wizard.
02-10-2011 02:34 PM
AKM stands for automatic key management.... anyway, 7920 is a B only phone and doesn't support G rates. so make sure you have B rates enabled on your router.
Make sure you use on the router wpa1+tkip+preshared key that you have to enter on your phone as well.
let us know how it goes.
02-10-2011 05:20 PM
02-10-2011 05:21 PM
02-11-2011 01:03 AM
things look ok.
can you test with an open ssid without encryption to see if it will work?
02-11-2011 01:06 AM
As far as I can tell the issue happens on an open network too. I'll have to double check. We have two phones on two different networks with the same issue so I feel like we're missing something easy.
Sent from my iPhone
02-11-2011 02:16 AM
Yeah let's double check that just to make sure that this is not due to some inter-op thing between the phone and the ap when using wpa. Let's go with a flat open auth no encryption to make sure that other things like dhcp and skinny are working fine as well.
02-12-2011 12:58 PM
Still no luck. We've tried two phones on 4 routers. DLink, Actiontec, Linksys, and another Linksys. So either for some reason neither of the phones work or we're missing a really simple option.
02-14-2011 11:27 PM
What firmware is on the 7920?
WPA-PSK was not supported initially.
It was added with version 2.0 back around 2005.
WPA2-PSK is not supported so ensure that WPA-PSK v1 using TKIP is enabled in the AP.
Set the 7920 for AKM mode then set the pre-shared key.
Advise to load 3.02 on the 7920.
02-14-2011 11:32 PM
It's running 3.0.2 the newest from the Cisco Site. I've ensured that WPAv1 was setup and I ensured that WEP didn't work also, along with no security. No matter what settings I put in and what settings the router is configured with even after a factory reset the phones still didn't connect (factory reset of the router and phone). So we're giving up and returning them end of this week.
02-15-2011 12:12 AM
I would start at ground zero with open authentication and no encryption then.
Aldo do you know which model phone you have? We offered a model for Americas, Europe, Japan and Australia/New Zealand.
Again it is the 7920 and not 7921 or 7925 correct?
Fyi, the 7920s are no longer supported by Cisco.
