Cisco ACS Engine appliance 1120 software upgrade
bright
I want to upgrade my Cisco ACS Engine appliance 1120 from software version 3.3 to the latest version (5.x). How do I go about this? Someone should help please.
George Stefanick
Hi Bright,
I might suggest posting this in the AAA section of the Cisco forum. You will get the help you need.
Nicolas Darchis
It is highly suspicious that you would have a 1120 appliance that is running 3.3
ACS 3.3 was with the ACS solution engine 1111, 1112 and 1113.
ACS 5 requires the appliance 1120/1121 so it requires an appliance change. I'm puzzled about how you could be running 3.3 for 1120 since there is no installation DVD for that.
As a general thing, one has to follow the ACS 5 migration guide on cisco.com that explains the process quite well. You need to go to acs 4.1/4.2 to migrate to 5.
http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/migrate.html
Nicolas
