Cisco 819 ISR / Access Point issue
RoyDean72672
     I am having an issue with my Cisco C819GW-LTE-MNA-AK9 ISR, when I try and connect to the embedded access point. It gives me a message stating the connection is refused.
This is a new ISR and I had never configured it before, any assistance and / or direction you can give would be great.
Roy
Mark Elsen
 - Check this guide and or set correct network parameters first before accessing the internal ap:
 https://www.cisco.com/en/US/docs/routers/access/800/880/software/configuration/guide/880_basic_device_wireless_config.html
 M.
Mark Elsen
 M.
Hey Marce,
I don't have it solved yet, email was acting up and I clicked the wrong button.
thanks for the direction and I have followed the basic setup down to step 8; this is where I run into the issue and get the message that the connection is refused. I have been searching the configuration guide and the internet trying to find something that would help, but so far nothing I have done will let me access the AP.
I did use the "IP unnumbered vlan 1" command when going through the setup.
The router itself is up, I have pinged out to a couple of DNS servers.
I have also tried to use the GUI to access the embedded AP but it cant access it either.
I will most likely reset back to factory when I get home from work and start again.
 - Ok, when you re-try also check the router logs, after the command in step is given. Look for more info's if any.
 M.
