Cisco 877W DNS problems
CSCO12348032
Frequent Visitor
Frequent Visitor
I have set up a Cisco 877W router to connect to our business broadband, however it doesn't give out DNS information to the clients.
A client will get an IP Address from DHCP ok, but doesn't get any DNS information.  I would expect that it would get one of the Open DNS server IP Addresses as its DNS server.
I have included the config below.
Current configuration : 4851 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
hostname ch_adsl_router
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1$3N1o$6G84AGWAHy0mAUw1HB67A.
username response privilege 15 secret 5 $1$QO99$fHpHFUdFeHnCy0Ox7zSuE.
clock timezone gmt 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 172.25.50.1 172.25.50.10
ip dhcp pool dpool1
network 172.25.50.0 255.255.255.0
default-router 172.25.50.4
dns-server 208.67.222.222 208.67.220.220
ip domain name response-ad.com
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip ssh version 2
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
no ftp-server write-enable
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid CH_Wifi
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 0001595E457D08173A
world-mode dot11d country GB outdoor
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
ip virtual-reassembly
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap callin
ppp chap hostname ek005t3171@adsl.vmbusiness.net
ppp chap password 7 08735F430C111C1A1E
interface BVI1
ip address 172.25.50.4 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip nat pool dpool1 172.25.50.11 172.25.50.250 netmask 255.255.255.0
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 172.25.50.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CCCCCC
* Un-authorized Access Is Strictly Prohibited. *
* If You Have Not Been Granted Permission To Access This Device, *
* Disconnect Now! *
* All access attempts will be logged. *
^C
banner motd ^CCCCCCC
_________ .__
\_ ___ \_____ ____________ |__|____ ____
/ \ \/\__ \ / ___/\____ \| \__ \ / \
\ \____/ __ \_\___ \ | |_> > |/ __ \| | \
\______ (____ /____ >| __/|__(____ /___| /
\/ \/ \/ |__| \/ \/
___ ___
/ | \ ____ __ __ ______ ____
/ ~ \/ _ \| | \/ ___// __ \
\ Y ( <_> ) | /\___ \\ ___/
\___|_ / \____/|____//____ >\___ >
_____ ________ _________.____
/ _ \ \______ \ / _____/| |
/ /_\ \ | | \ \_____ \ | |
/ | \| ` \/ \| |___
\____|__ /_______ /_______ /|_______ \
__________ __
\______ \ ____ __ ___/ |_ ___________
| _// _ \| | \ __\/ __ \_ __ \
| | ( <_> ) | /| | \ ___/| | \/
|____|_ /\____/|____/ |__| \___ >__|
^C
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
This issue was answered in a previous post Sir.
https://supportforums.cisco.com/discussion/10981336/dns-not-working-cisco-877
HTH,
William Kuczmera
I came across that post, hence why I have configured the ip name-server command and the dns-server command within the dhcp pool.
I still dont get any DNS info passed to the client.
CSCO12348032
Frequent Visitor
Frequent Visitor
Issue seems to be resolved.  It looks like it is an issue with the DHCP lease.
When I connect today, I am getting the DNS information and can access the Internet ok.
