Cisco 881w AP Gui problem
FlorisClaeys
I'm trying to configure the Cisco 881w Wireless Router i bought, but when I try to access the internal AP using the web page, the web page is broken and i cannot sign in to it. I searched the forums and the only thing I can find is that this bug was found in a version of the IOS 12. Since I'm using IOS 15, i though i could try to update it (i'm not running the latest version), but I can't download it since I don't have a professional account, neither can I open a TAC.
Can someone help me?
Thank you very much,
Floris Claeys
tfraij
Hello Floris,
if the AP in your ISR is not showing GUI i see you are hitting this bug
CSCtc94776 ap801 upgraded to 12.4(21a)JA01 breaks the ap801 GUI interface.
Symptom:
Upgrade of the ap801 to 12.4(21a)JA01 breaks the gui interface. It will not
load properly and only the "enter" button is observed.
Conditions:
Upgrade to 12.4(21a)JA01
Workaround:
Configure the ap801 via the CLI or access the ap gui page as follows:
http:///ap_express-setup.shtml
Best regards
Talal
please rate answers that you find useful , and mark as answered - when it is :-) - so others can find it easily
tfraij
Hello Floris,
Symptom:
Conditions:
Workaround:
Best regards
Talal
wow the workaround actually works like a charm! Thank you very much for the quick answer, I only tried it now because I dodn't have the time before. Thank you very much!
Floris
