Cisco 881W AP801 Web interface broken
Sascha Ferley
Community Member
When upgrading the AP801 i have noticed that the web interface no longer works.
The firmware currently loaded is the autonomous version ap801-k9w7-mx.152-4.JA1
Nothing showing amiss otherwise.
Flash:
#sh flash
Directory of flash:/
    2  -rwx           5  Jul 31 2017 08:38:51 -07:00  private-config
    3  -rwx        3126  Jul 31 2017 08:38:51 -07:00  config.txt
  158  drwx         640  Jul 15 2010 11:51:54 -07:00  ap801-k9w7-mx.152-4.JA1
    4  -rwx        2072  Jul 31 2017 08:38:51 -07:00  private-multiple-fs
  153  drwx         128  Dec 31 1969 16:09:17 -08:00  ap801-rcvk9w8-mx
    6  -rwx         544  Jul 31 2017 08:38:40 -07:00  env_vars
31223808 bytes total (16136704 bytes free)
The web page loads fine but doesn't interface at all with the CLI or writes to the config file. Nor does it read from the config file.
Interfaces are listed as empty and none of the configuration that the AP actually uses is populated in the web interface.
Anyone have any idea?
S.
0 Replies 0
