Cisco 9105AXW will not auto provision
raymondlmcd
I can connect to the CLI using the serial cable and it continues to show the links down or up. Yet will not let me use the Cisco Catalyst Wireless Mobile Application to auto provision the device. Brand New out of box.
16 Replies 16
Hello All,
Thank you for your help my AP had to be upgraded first  I think it was :
archive dowload-sw tftp://x.x.x.x/filename
First then the  ap-type ewc-ap tftp://1.2.3.4/ap1g8 tftp://1.2.3.4/C9800-AP-iosxe-wlc.bin was able to be used because firmware didn't have the "ewc" command
found correct info:
>archive download-sw /reload tftp://<IP of TFTP server>/ap1g8
...followed by...
>ap-type ewc-ap tftp://<IP of TFTP server>/ap1g8 tftp://<IP of TFTP server>/c9800-ap-iosxe-wlc.bin
raymondlmcd
I think your AP is in CAPWAP mode and you want to convert it to EWC - is that correct? yes
I put on a different network and can ping and ensured the TFTP port is running on a win-10 pc with solarwinds
