Cisco 9120 in EWC with WLAN MAC local filtering issue
Edgar078
Good day,
I have an EWC Access Point 9120 which has an SSID with PSK and MAC filtering local, however it is not allowing me to connect the devices, it gives me a message:
Jan 26 17:11:30.353: %MAB-5-FAIL: Chassis 1 R0/0: wncd: Authentication failed for client (0c9a.3cd2.bab3) with reason (AAA Server Down) on Interface capwap_90000004 AuditSessionID 00000000000001ED3D5C65E8
Jan 26 17:11:30.494: %CLIENT_EXCLUSION_SERVER-5-ADD_TO_EXCLUSIONLIST_REASON_DYNAMIC: Chassis 1 R0/0: wncd: Client MAC: 0c9a.3cd2.bab3 was added to exclusion list associated with AP Name:AP-SALA-JUNTAS, BSSID:MAC: 0000.0000.0000, reason:802.11 association failure
Jan 26 17:11:30.494: %SESSION_MGR-5-FAIL: Chassis 1 R0/0: wncd: Authorization failed or unapplied for client (0c9a.3cd2.bab3) on Interface capwap_90000004 AuditSessionID 00000000000001F23D5C6675. Failure reason: Authc fail. Authc failure reason: AAA Server Down.
Rich R
Did you configure as per the guide?
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213922-configure-mac-authentication-ssid-on-cis.html#toc-hId-2036295870
15 Replies 15
Mark Elsen
                           >... with reason (AAA Server Down) on Interface ...
 - For some reason an AAA server is being contacted  ; review the running configuration  with :  show running-config | inc aaa
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
Hello @Rich R
Yes, I have it configured like the guide you shared with me.
What version of software are you using?
17.09.04
It appears that you have AAA configured on the SSID, as its trying to send the auth to a AAA server
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hello @Haydn Andrews
I have configured this part according to the guide.
Authentication is local, there is no external radius server or tacacs.
Can i see the wlan l2 secuirty page
MHM
Hi @MHM Cisco World
This is the WLAN configuration
Regards!
Authorization list name is different between l2 secuirty and what you previously share?
Also if you match name make sure thst ypu select Local and not click authc.
Do that and make sure the mac is add to authz and check again.
MHM
ChaseFF
I have the same issue on 17.9.4a.  Without the Authorization List, my PSK Authentication works and can join the SSID, but as soon I add the Authorization List, the PSK stops working, and I get Authentication failures "Authentication failed for client (abcd.1234.5678) with reason (AAA Server Down)" even though I did not add AAA Server Authentication.
Rich R
I have just tested it on my EWC running 17.13.1 and it works fine.
Note that error message is misleading.  That actually just means it did not find a username (MAC) match in the local list.  I confirmed that in my testing.
If you followed the instructions precisely per the guide then your MAC address username is entered in lower case without any punctuation (no dots, no colons, no dashes).  If you put . : or - in your mac then it won't match.
Also make sure you have Allow AAA Override enabled on your Policy Profile.
ChaseFF
There it was plain as day.
"Write the mac address in all lowercase without a separator"!!!!
Thanks Rich for the smack in the back of the head
