cisco 9130AXE-E regulatory domain problem with 5G
shlomoi
Hi friends,
We recently purchased a 9800 controller and  20 AP model  9130AXE-E.
I set  the controller but the AP does not transmit a 5G frequency. When I check the AP status I see that the
regulatory domain is -E.
I set the country code to my country israel  -L. But I still have the same  problem
Is it possible to change the regulatory domain through the controller.
shlomo itzhak
2 Accepted Solutions
Radu96069
Not 100% sure but I remember reading somewhere that the regulatory domain is "hard-coded" in the product.
You can change the county from the controller but only countries covered by -E domain.
Wireless LAN Compliance Lookup (cisco.com)
I think you need to change those AP with ones that are made for your regulatory domain( -I). Check with the partner.
Rich R
Is it possible to change the regulatory domain through the controller?
NO
Radu96069
Thank you very much for your help
Shlomo itzhak
ammahend
For Israel regulatory domain is I not E, the AP might not work.
-hope this helps-
Rich R
NO
