Cisco 9136 LACP not working
ANKUSH_SINGLA
Hello All,
I am suing C9800-L-F-K9 with 17.9.3 image and trying to use both ports for C9136I Wap.
WAP is connected to C9300-24UX model with image 17.9.3
Issues
Switch is configure with LACP Config and LAG is enabled on AP join profile in WLC
I am seeing below error on switch
%ETC-5-L3DONTBNDL2: Tex/x/x suspended: LACP currently not enabled on the remote port.
your inputs will be helpful, pls help
8 Replies 8
Can i see the page you config LAG ?
Did you use lacp in wlc ? Or run mode ON?
MHM
we enabled LAG on AP Join Profile not globally . in WLC i do not see any option for Mode on
So the WLC not support lacp
You need to make port channel in switch use mode ON
MHM
   >...in WLC i do not see any option for Mode on
   - It's to be set on the switch , as in (e.g.) :
 switch# configure terminal
switch(config)# interface fastethernet 0/1
switch(config-if)# channel-group 5 mode on
  Change interface name  and channel group number accordingly and verify settings with :
                  show ethernet channel summary
 M.
marce1000
         - Set LACP mode on , for the AP intended LACP ports ,
 M.
@marce1000 @MHM Cisco World  thanks for reply , does this mean WiFi6E waps will only work on Mode on not active ?
I think Yes'
If you not see lacp option in general (and also check it in management tab) then Yes it support only ON mode.
MHM
- Indeed ,
M.
