Cisco 9300 Switch Missing Wireless Setup Icon
Spidey's Curse
Visitor
I am trying to configure a C9300 switch for wireless capabilities.
I'm currently running Cisco IOS XE Software, Version 17.06.05. I have enabled the wireless controller, however, I am trying to add a WAP and struggling to get this figured out.
The wireless controller software is also at 17.6.5 so everything is updated.
All the YouTube videos and KB articles Ive read all show a wireless icon at the top of the WebUI then I should be able to click on and get basic/advanced settings for wireless setup, but that is completely missing.
Am I totally missing something here?
I'm currently running DNA Advantage and Network Advantage. Is this a licensing issue?
Also, this may be a stupid question, but when I try to find an answer for "9300 wireless controller configuration" pretty much all results come back with 9800 information.
The wireless controller for the 9300 is also for the 9800 as you can see in this link
So Im assuming I should be using the same troubleshooting steps to configure the wireless controller for the 9800, is that correct?
Any help would be very much appreciated. Thank you in advance!
6 Replies 6
Mark Elsen
     - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/wireless-sub-package.html
  >...Cisco Catalyst 9800 Wireless Controller software on the Cisco Catalyst 9300 switches must be provisioned and deployed on the switch using Cisco DNA Center, and it cannot be configured as a standalone controller. For mode details, see the Cisco Catalyst 9300 Series Switches Hardware Installation Guide.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
check here my BLOG step by step :
https://www.balajibandi.com/?p=1449
BB
Thank you for the reply.
So, I was actually able to do everything in your blog post. At the bottom of your page you say "In the next section, I will cover configuring WLC and AP joining to WLC."
I think this is actually the section that I need, but I cant seem to find it on your blog.
Could you please provide that link?
Once you get the "controller" functioning on your 9300, then follow the 9800 guide to setup the management and wireless management interface.  Once you have figured that piece out, the easiest way is to connect the ap to the same vlan as the wireless management/management vlan.  Also make sure the the ap you are trying to join to the controller is supported on the code version.  Search "Cisco wlc matrix" to validate compatibility.
-Scott
Maybe you know this already but just to make sure...
Presume you know that autonomous WLC on 9300 is end of life after 17.3 as per
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-744299.html?
So if you're trying to use it on 17.6 then only SDA mode is supported:
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-sda-design-guide.html
So you'll be configuring that on DNA Center only.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Ah, I did not know that. Thank you so much! That was really helpful
