Cisco 9800 WLC - Management interface access from WIFI...???
Beacon Bits
Hello
Environment:  I have installed Cisco 9800 WLC cluster environment with around 100 APs.
Issue: it seems to have some roaming issue even though I have enabled 802.11 kvr amendments. So I want to run a test via Cisco Mobile Android app. To do so WLC Management access should be allowed through the WiFI.
I have this on our old Cisco 5520 WLCs but on these new Cisco 9800 WLC I cannot find this option!
Question: How can I enable Management Wireless Access over WIFI?
Any help ???
Beacon Bits
Thanks, Everyone I have found the answer by digging int Cisco WLC 9800.
Configuration > Wireless: Wireless Global > Management Via Wireless: Enable
The question is, do you really want to allow your wireless users to manage your WLC?
By enabling this, you allow attacks against the WLC from the wireless network, so make sure you always keep the software up to date.
