Cisco Access Point is not Broadcasting
aslam.bajwa
Level 3
Level 3
Hello ,
one of my Access Point is showing up in WLC but not broadcasting .
any Idea Please advice.
7 Replies 7
Scott Fella
Makre sure the radios are up, the 802.11abgn radios bands are enabled and you have a valid ssid.  You need to provide more info so we can drill down on the issue.  Is it all Ap's or just one... multiple ssids?
Post your show run-conf and let us know what the ssid is.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Scott Fella
Also post the show ver from the AP.
Scott
-Scott
Fella ,
thanks for your reply ,
ther 13 APs , one is showing not broadcasting . i am not much experienced in Wireless and one my customer facing this issue . what els i can check on site ?
Make sure the AP is in the correct AP Group... can you get a show run-config?
Scott
-Scott
Only one AP?
1.  Make sure all the radios for this particular AP is up/up.
2.  AP Group - make sure the AP is a member of the AP group where the SSID is assigned
You'll need to provide more information.
David Ritter
Level 4
Level 4
With newer WLC code, the radios within the AP are OFF by default.  More buttons to push.
And you may have the 'Out-of-Box' AP Group feature enabled as do I.  However, I have none in the 'dafault' group.
Rasika Nayanajith
Hi Islam,
In WLC GUI ( go to Wireless tab) & select the AP
1. Check the "Admin Status" of the AP. It should be enable
2. Advanced setting page of AP, "AP Group name" set to be correct ap group. If you haven't create any additional ap groups it should be in "default-group"
3. Also check in the interface tab of the AP configuration both radio 0 & radio 1 interface Operation Status is UP
Rasika
*** Pls rate all useful responses *****
