Cisco Access Points - Cabling issues
jamesg89
Community Member
I just wondering if there was any documentation that shows what the Maximum cable length can be for Cisco to support their Access Points
8 Replies 8
Leo Laohoo
100 meters
Mark Elsen
  E.g. : https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/deployment-guide-c07-743490.html#:~:text=Note%3A%20The%20Ethernet%20cable%20recommended,328%20feet%20(100%20meters).
 >...The Ethernet cable recommended is CAT-6 with a maximum distance of 328 feet (100 meters). Power required at the Power Source Equipment (PSE) will depend on the cable length and other environmental issues.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
jamesg89
Community Member
thanks for the quick replies both...
would this be the same for Cisco C9124A?
Yes!
M.
jamesg89
Community Member
Thank you, where could i find the documentation that would show that against that particular AP, I've searched everywhere, could do with it as evidence to a discussion I am having.
The standard maximum distance for GigabitEthernet and PoE is 100 meters.
 - FYI : https://www.genuinemodules.com/what-is-the-ethernet-100-meter-limit_a3226#:~:text=Ethernet%20Cable%20Length%20Limit%3A%20100%20Meters&text=The%20standard%20Ethernet%20cable%20length,technical%20specifications%20for%20Ethernet%20networks.
 M.
Rich R
Cable length is a function of the ETHERNET and POE standards not the AP specifications!
Refer to the relevant IEEE 802.3 standards documents for those cable length specifications.
Remember longer cable = greater power loss for POE.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
