Cisco Access Points Not Connecting To Controller AIR-CAP2702I-E-K9
ishaq
Hello Support,
I have trouble where Cisco Access Points AIR-CAP2702I-E-K9 Not Connecting To Controller
Below is the Error
*Jan 8 03:59:35.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: x.x.x.x peer_port: 5246
*Jan 8 03:59:35.347: %DTLS-5-ALERT: Received FATAL : Certificate unknown alert from x.x.x.
*Jan 8 03:59:35.347: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to x.x.x.x
How can I get this resolved
Ishaq.
5 Replies 5
Jurgens L
Level 3
Level 3
Can you provide the following outputs on your WLC:
show sysinfo
show time
Details Attached
Sandeep Choudhary
Correct the time on WLC.
If AP still fails to join then conenct console cable to AP and paste the complete bootup process.
Dont forget to rate helpful posts
@ Sandeep
It worked
Thank you
Leo Laohoo
That firmware is deferred. It is even vulnerable to KRACK.
For a WLC servicing APs in the ME, I'd reconsider using that version, particularly all the current hostile networking activities by adversaries.
