Cisco ACS Maximum Concurrent Sessions
farage
Frequent Visitor
Frequent Visitor
I have Cisco WLC 8510 which using Cisco ACS 5.7 to authenticate wireless users using PEAP authentication. I configured Group Mapping on the ACS to map the external groups (AD Groups) to the local ACS group, then I configured MAX session user settings & group setting to 3 but these settings didn't work for me.
Any Suggestions.
patoberli
Do you send accounting data from your WLC to the ACS?
Do you have CoA enabled on the WLC?
Please note, I don't know if it's actually supported or not, but I'm fairly sure the two points above would need to be enabled for it to work.
