Cisco air-2702i-uxk9 not responding
itrm
We had a Cisco air-2702i-UXK9 access point which was behaving abnormally. It used to connect to the WLC for a few minutes and after that, it used to get disconnected from the WLC. I have connected the console cable and have reset using mode button. Now it is showing the following when trying to boot. I am unable to get into the ap prompt as it is not responding to any key of the keyboard.
IOS Bootloader - Starting system.
flash is writable
Antigua Board
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 87 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 22491648
flashfs[0]: Bytes available: 18667008
flashfs[0]: flashfs fsck took 23 seconds.
Base Ethernet MAC address: 78:72:5d:ac:3c:10
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.153-3.JF9/ap3g2-k9w8-mx.153-3.JF9"...#########################
File "flash:/ap3g2-k9w8-mx.153-3.JF9/ap3g2-k9w8-mx.153-3.JF9" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Antigua Board Pre-Pilot
40MB format
flashfs[0]: flashfs fsck took 25 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 1 seconds.
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/ap3g2-k9w8-mx.153-3.JF9/ap3g2-k9w8-xx.153-3.JF9'
Loading "flash:/ap3g2-k9w8-mx.153-3.JF9/ap3g2-k9w8-xx.153-3.JF9"...#################################################
File "flash:/ap3g2-k9w8-mx.153-3.JF9/ap3g2-k9w8-xx.153-3.JF9" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2700 Software (AP3G2-K9W8-M), Version 15.3(3)JF9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sun 25-Nov-18 00:39 by prod_rel_team
40MB format
Initializing flashfs...
flashfs[2]: 87 files, 9 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 22491648
flashfs[2]: Bytes available: 18408960
flashfs[2]: flashfs fsck took 20 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Copy in progress...CCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8764 8000 0 A8000000 A8010000 0
Rate table has 650 entries (20 legacy/224 11n/406 11ac)
POWER TABLE FILENAME = ram:/U2.bin
Radio1 present 8864 8000 0 80000000 80100000 4
POWER TABLE FILENAME = ram:/U5.bin
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP2702I-UXK9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW2216N89B
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.5.140.0
Access Point Type: World Mode
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 78:72:5D:AC:3C:10
Part Number : 73-15824-04
PCB Serial Number : FOC22150ZSE
Top Assembly Part Number : 068-100395-02
Top Assembly Serial Number : FCW2216N89B
Top Revision Number : B0
Product/Model Number : AIR-AP2702I-UXK9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:25.103: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:25.563: Registering HW DTLS
*Mar 1 00:00:26.419: Starting Ethernet promiscuous mode
*Mar 1 00:00:28.739: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:28.739: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:31.239: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:31.351: loading Power Tables from ram:/U2.bin. Class = UX
*Mar 1 00:00:31.355: record size of 3ss: 1168 read_ptr: 62486F6
*Mar 1 00:00:36.551: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:36.595: loading Power Tables from ram:/U5.bin. Class = UX
*Mar 1 00:00:36.631: record size of vht: 2904 read_ptr: 62486F6
APAVC Registering AVC licences on the AP to make sure we enable advanced PP
*Mar 1 00:00:38.043: SCHED: Ethernet Bridge Process: install watched boolean System Initialized(6230934), os:1 ah:0APAVC Protocol list already initialized.
*Mar 1 00:00:38.043: Start STILE Activation
APAVC: Succeeded to activate all the STILE protocols.
APAVC: Registering with CFT
*Mar 1 00:00:38.287: APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching Original Buffer pool for system use
*Mar 1 00:00:39.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:39.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Jun 2 12:55:55.127: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 39
*Jun 2 12:55:55.127: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 39
*Jun 2 12:55:55.139: %SYS-5-RESTART: System restarted --
*Jun 2 12:55:55.139: %SNMP-5-COLDSTART: SNMP agent on host AP7872.5dac.3c10 is undergoing a cold start
*Jun 2 12:55:55.211: SCHED: Ethernet Bridge Process: remove watched boolean System Initialized(6230934)
*Jun 2 12:55:55.215: SCHED: Ethernet Bridge Process: install watched queue Soap BVI input queue(D1ABAC0), os:0 ah:0
*Jun 2 12:55:55.275: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Jun 2 12:55:55.275: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Jun 2 12:55:55.275: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Jun 2 12:55:55.327: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Jun 2 12:55:55.327: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
lwapp_crypto_init: MIC Present and Parsed Successfully
*Jun 2 12:55:56.587: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Jun 2 12:55:56.587: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 2 12:55:56.587: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jun 2 12:55:57.671: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
*Jun 2 12:56:01.251: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Jun 2 12:56:01.251: DPAA Initialization Complete
*Jun 2 12:56:01.251: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Jun 2 12:56:02.251: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Jun 2 12:56:13.455: Currently running a Release Image
*Jun 2 12:56:13.479: Using SHA-2 signed certificate for image signing validation.
%Default route without gateway, if not a point-to-point interface, may impact performance
*Jun 2 12:56:25.731: AP image integrity check PASSED
*Jun 2 12:56:25.771: Non-recovery image. PNP Not required.
*Jun 2 12:56:25.779: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
*Jun 2 12:56:25.807: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 2 12:56:26.911: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 2 12:56:26.919: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jun 2 12:56:27.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 2 12:56:28.135: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun 2 12:56:29.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
*Jun 2 12:56:35.819: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Jun 2 12:56:36.819: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 started - CLI initiated
Not in Bound state.
*Jun 2 12:57:35.835: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
Also, if I am trying to reset the AP using mode button, it is showing the following and still not responding to any key of the keyboard.
flash is writable
Antigua Board
40MB format
flashfs[0]: 86 files, 10 directories
button pressed for 20 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap3g2-k9w7-tar.default
Unable to create temp dir "flash:/update"
examining image...
DPAA Set for Independent Mode
tide_boot_speed = 1000
DPAA_INIT = 0x0
%Error opening tftp://255.255.255.255/ap3g2-k9w7-tar.default (connection timed out)ap:
KIndly help.
Thanks for in advance.
8 Replies 8
patoberli
Here is the error:
The AP is in a network where it can discover the WLC.
I assume either DHCP is not offering an IP to the AP or option 43 isn't configured. More information:
https://mrncciew.com/2013/03/17/ap-registration/
Thank you for your reply. But, primarily I need to access the AP through Console and I am unable to access the device to reconfigure and update firmware also. No key is responding when connected through Console cable.
did you try another laptop and new console cable ?
This console cable is working with other devices on this laptop
Make sure you have configured your serial console correctly. APs don’t like if you have flow control or parity enabled.
Checked and found both are negative
Then it should work.
But anyway, if the DHCP is correctly configured and the AP can reach the WLC, then it will automatically do a software upgrade. You don’t need to do this manually for CAPWAP devices.
Thanks, I also had been facing the same issue with my AP CAP2702i-D-K9. But, after turning Flow control and Parity to negative the AP, I easily get into the console to AP.
