cisco air-ap1142n-a-k9 wireless access point wpa2 configuration issue
sanjeevmahadani
HI Folks,
I am very new on Cisco Wireless, just i have purchased new cisco air-ap1142n-a-k9 wireless access point, trying to configure the wpa2 configuration for security reason, but unable to configure in any security mode. So currently my AP is working no security / encryption mode.
Could any one can help and suggest me I'll appreciate if i'll get any documents so security issue can be resolved.
Sanjeev
ok Great
Don't forget to rate correct answer and flag the thread as answered
19 Replies 19
maldehne
Hello Sajeev
Please check the following link:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
Please make sure to rate correct answers
Hi Maldehne,
I appreciate for quick reply, as already i have downloded and followed and even configured at client side also, but still facing the Radius authentication issue and unable to login into the AP.
sanjeev
My friend
What kind of EAP are you looking for?
What is the supplicant utility?
What is the RADIUS server you are using?
Send me the output of show run
I am sorry sir,
Unable to login into device through consol port, only i can open this through web.
sanjeev
I am sorry just tried below is conf.
AP11401#sh run
Building configuration...
Current configuration : 2469 bytes
version 12.4
no service pad
service password-encryption
hostname AP11401
enable secret 5 $1$bHE1$KZwM5zpeJYIWqjQP/lUo2/
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid MIWireless
   authentication open
   guest-mode
eap profile sanjeev
method leap
dot1x credentials Sanjeev
username sanjeev
password 7 104F0B1A0112140C
username sanjeev password 7 070E234F4A
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid MIWireless
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid MIWireless
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.20.245 255.255.255.0
no ip route-cache
ip default-gateway 192.168.20.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
snmp-server community MIString RO
radius-server local
  no authentication eapfast
  no authentication mac
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
wlccp ap username br password 7 011204075F0E0008
wlccp ap eap profile sanjeev
line con 0
terminal-type ansi
line vty 0 4
terminal-type ansi
end
AP11401#
Hi Maldehne,
Above configuration is without WPA2.
Sanjeev
Oh Man
Here is a simple config for WPA PSK if you want , because what you have configured is not correct at all.
AP(config)#dot11 ssid test
               #authentication open
               # guest-mode
               # authentication key-management wpa version 2
               #wpa-pask ascii ...................
               #exit
AP(config )# interface dot11radio 0
               #encryption mode ciphers aes-ccm
               #ssid test
               # no shut
               # exit
Hi Maldehne,
As suggested by you, should i change the above configurations and security will enable on the device and before login into the AP will this requiest for the password...?
Sanjeev
not sure what do you mean will request password?
Just add the above config and make sure that your AP has ip address defined for the BVI1 interface with the above config it should work.
I recommend you to go and read the config guide for Aironet APs.
Hi Maldehne,
I have tried but getting below error.
SanjeevAP(config-ssid)#authentication key-management wpa version 2
Dot11Radio1 Error: Encryption mode cipher is not configured
tried for this also....
                #ssid test
                # no shut
                # exit
Please issue the following command:
AP(config)# interface dot11radio 0
               # no ssid test
               #exit
then
               # guest-mode
               #exit
After that
AP(config)#interface dot11radio 0
               # ssid test
               # no shut
How it goes now ?
Tried below is sh run...
SanjeevAP#sh run
Current configuration : 1849 bytes
version 12.4
no service pad
hostname SanjeevAP
enable secret 5 $1$5Vb.$Cf3RtfkMiSb03QslUsqAT1
aaa new-model
aaa group server radius SanjeevAP
server 192.168.20.250 auth-port 1645 acct-port 1646
aaa authentication login eap_methods group SanjeevAP
ip name-server 4.2.2.2
ip name-server 8.8.8.8
dot11 syslog
dot11 ssid SanjeevAP
   authentication open
   guest-mode
username Cisco password 7 00271A150754
bridge irb
no ip address
no ip route-cache
ssid SanjeevAP
antenna gain 0
station-role root
bridge-group 1
no ip address
no ip route-cache
shutdown
ssid SanjeevAP
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.20.250 255.255.255.0
no ip route-cache
ip http server
radius-server local
  nas 192.168.20.250 key 7 080F437E080A16001D1908
  group testuser
bridge 1 route ip
line con 0
line vty 0 4
end
SanjeevAP#
SanjeevAP#
Below is few
SanjeevAP(config)#interface Dot11Radio0
SanjeevAP(config-if)#no ss
SanjeevAP(config-if)#no ssid SanjeevAP
SanjeevAP(config-if)#enc
SanjeevAP(config-if)#encryption mod
SanjeevAP(config-if)#encryption mode ci
SanjeevAP(config-if)#encryption mode ciphers aes
SanjeevAP(config-if)#encryption mode ciphers aes-ccm
SanjeevAP(config-if)#exit
SanjeevAP(config)#dott
SanjeevAP(config)#dot11
SanjeevAP(config)#dot11 ss
SanjeevAP(config)#dot11 ssid SanjeevAP
SanjeevAP(config-ssid)#authentication op
SanjeevAP(config-ssid)#authentication open
SanjeevAP(config-ssid)#gu
SanjeevAP(config-ssid)#guest-mode
SanjeevAP(config-ssid)#wp
SanjeevAP(config-ssid)#wpa-psk asc
SanjeevAP(config-ssid)#wpa-psk ascii .....
Error: Key-management WPA is requried for WPA-PSK
SanjeevAP(config-ssid)#exit
SanjeevAP(config)#interface dt
SanjeevAP(config)#interface dot11rad
SanjeevAP(config)#interface dot11radio 0
SanjeevAP(config-if)#ss
SanjeevAP(config-if)#ssid SanjeevAP
SanjeevAP(config-if)#no shut
SanjeevAP(config-if)#^Z
