cisco AIR-AP1230B-E-K9 - WPA2 capable???
FEDEX690220
Hi there,
I would like to implement WPA2 in my Cisco APs 1200 series but it seems the AP is not WPA2 capable. Is there a way to upgrade my AIR-AP1230B-E-K9 to be able to add this feature or I will have to buy a new one?
And I also need to do the same with my cisco AIR-AP1231G-E-K9 which I suppose is the same as the other.
Thanks for helping me out
Rob Huffman
Hi Luis,
The 1230B would require a Radio upgrade to support WPA2.
So you would need to install the Radio Upgrade kit to install the (AIR-MP21G-A-K9).
Cisco Aironet 1200 Series Access Point Radio Upgrade Instructions
http://www.cisco.com/en/US/docs/wireless/access_point/1200/radio/upgrade/guide/12rupgrd.html
Cisco Aironet 802.11G 1100 and 1200 Series Access Point Upgrade Kit
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps430/product_data_sheet0900aecd801b9233.html
I'm not 100% sure that these kits are still available (but I think they are :)
As nicely shown here :)
Wi-Fi Protected Access 2 (WPA 2) Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
Hope this helps!
Rob
Thanks a lot Rob,
I really appreciate it! Now, I only have to find if the kit is available.
Cheers
Hi Luis,
You are most welcome my friend! I just tried to Google "AIR-MP21G-E-K9 kit" and found alot of hits, so you should be good to go :)
Cheers!
Rob
Yes, That's what I did and I already got the prizes.
Thank you!
