Cisco AIR-AP1252AG-A-K9 upgrade to LWAPP
Dear Experts,
I am trying to upgrade the AIR-AP1252AG-A-K9 to LWAPP. I have the tftp server ready with IOS c1250-rcvk9w8-tar.124-21a.JA2.tar
when I enter the following archive comman, I get an error
archive download-sw /f /0 tftp://10.10.2.10/c1250-rcvk9w8-tar.124-21a.JA2.tar
% Invalid input detected at '^' marker.
here is the show version output
ap#sh version
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(10b)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 30-Jan-08 12:04 by prod_rel_team
ROM: Bootstrap program is C1250 boot loader
BOOTLDR: C1250 Boot Loader (C1250-BOOT-M) Version 12.4(18a)JA1, RELEASE SOFTWARE (fc1)
ap uptime is 3 hours, 8 minutes
System image file is "flash:/c1250-k9w7-mx.124-10b.JA1/c1250-k9w7-mx.124-10b.JA1"
Please help.
2 Accepted Solutions
Hi Mohammed,
For the LWAP conversion, use the recovery image ( e.g  c1250-rcvk9w8-tar.124-21a.JA2.tar). We can use the same command on the autonomous AP priviledge mode.
AP#archive download-sw /force-reload /overwrite tftp://10.10.10.1/c1250-rcvk9w8-tar.124-21a.JA2.tar
Try this .
Dont forget to arte helpful posts.
9 Replies 9
Scott Fella
I don't see where it's marking an error. Try the /r /o
-Scott
Thank you so much for your reply.
Please find the screen shot with the command error. It doesnt seem to recognise the command parameter download-sw.
Here is the commands I tried.
archive download-sw /f /0 tftp://a.b.c.d/c1250-rcvk9w8-tar.124-21a.JA2.tar
archive download-sw /overwrite /reload tftp://a.b.c.d/c1250-rcvk9w8-tar.124-21a.JA2.tar
archive tar /x  tftp://a.b.c.d/c1250-rcvk9w8-tar.124-21a.JA2.tar flash:
(a.b.c.d is just for hiding the actual ip)
Thanks.
Thank you for your valuable comment. I will try them on the AP and get back to you.
I really honour your efforts and will rate your comments as I complete with the commands.
I was actually trying to convert it from Autonomous to LWAPP.
Thanks.
Hi Mohammed,
Try this .
The mode button can be used to convert either way.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thanks so much Scott and Sandeep.
It worked fine.
Regards.
TC Network
Dear Mohammed
I am also trying to join this AP to controller, can you please share me the OS file. This device is EOS then we can not download from Cisco.
Thank you
