Cisco AIR-AP1832I-E-K9 - AP not connecting to controller
ketansoni1
Hi All,
I have configured a master controller with a new firmware installed
AIR-AP1830-K9-8-3-112-0.tar to be a ME
The Management IP i provided is 192.168.108.99 - This is off the network.
For me to setup the secondary AP, I have a few questions:
1/ Do I use the below pre-installed imagine or download a new one > If so which one would I use
2/ Do I used CAPWEB for the AP to auto discover the master controller 192.168.108.99
3/ As the Master controller is off the network > the new AP will not be able to fine the controller.  Is there another way for me to re-configure the master controller, set the IP so it's on my network, and then the 2nd AP would see the controller?
4/ I have two of the same AP's, would you recommend using one as a fail over? if so how could i set this up.
Please see output of the 2nd AP
cisco AIR-AP1832I-E-K9 ARMv7 Processor rev 0 (v7l) with 966404/747668K bytes of memory.
Processor board ID KWC205202GN
AP Running Image : 8.2.141.0
Primary Boot Image : 8.2.141.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : 2f195c98fe73445b715e314c6efc689c
NSS FW version : NSS.AK.1.0.c10-00017-E_custC-1.67978.1
03/22/2017 07:49:49.0222] CAPWAP State: DTLS Teardown
[*03/22/2017 07:49:53.7707] CAPWAP State: Discovery
[*03/22/2017 07:49:53.8107] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/22/2017 07:49:53.8107] Discovery Response from 192.168.108.99
[*03/22/2017 07:50:03.0000] CAPWAP State: DTLS Setup
ketansoni1
Hi All,
Would anyone be able to advise on this?
Many thanks
