06-30-2015 09:50 AM - edited 07-05-2021 03:29 AM
I run into some issues with powering few AP 1702i . Data sheet stated the power cons. 15.4W
Which the Pwr injector : AIR-PWRINJ5 should do. The POE requirements are 802.3af.
However in real world when running both radios (2.4 and 5 GHz) the 5GHz radio is not running on full power . It is on 15dBm instead of 22 dBm while running on AIR-PWRINJ5 . For POE going from HP-5406zl ( with 17W per port ) one AP has 5GHz on full 22dBm and the other one 17 dBm.
I will try to to get more juice from HP as it should be 802.3at but what about the AIR-PWRINJ5 ?
I was thinking about use AIR-PWRINJ4 as it goes to 20W but the output from AIR-PWRINJ5 is 48V/0.32A and AIR-PWRINJ5 has 56V/ 0.55A .
Or is there any other option .
We have to use both powering options for different AP's.
Thanks for your help.
06-30-2015 10:21 AM
That's not unusual. In the 5GHz, there are different maximum power settings per channel.
You should be able to go and pull this document
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/channels/reference/1700-pwr-chn.xlsx
HTH,
Steve
06-30-2015 11:26 AM
Thanks Stephen, that totally explains it.
S o the question is, can use AIR-PWRINJ4 even when it has different Voltage/amp parameters from AIR-PWRINJ5.
only relavant data sheet I found is this one :
http://www.cisco.com/c/en/us/td/docs/wireless/technology/poe/technical/reference/Power.html
But there is no mention of a 1700 series...
