Cisco AIR-CAP3602I-N-K9 Standalone Mode
Peter Sheridan
I was able to get my hands on a Cisco  AIR-CAP3602I-N-K9, but understand it will only work with a WLC.
Is it possible to convert it into a standalone AP?
Peter
5 Replies 5
Sebastian Pusta
Yes, it is possible. Basically, it is done by changing the AP image from ap3g2-k9w8... to ap3g2-k9w7...
You can refer to the document below for details on how it is done.
https://supportforums.cisco.com/document/57476/lwapp-autonomous-conversion-and-vice-versa-access-points
I have to mention that you will need a CCO account and service contract associated to that account in order to have the right to download the image.
Best regards,
Sebastian
Hi Sebastian,
Thanks for your reply.
I found a lot of those guides last night, but when i try and enter
debug lwapp console cli or debug capwap console cli
I don't have the option, all i've got is.
AP#debug capwap ?
  am           KAM-AP debug
  client       CAPWAP Client Debug Options
  flexconnect  CAPWAP FlexConnect Debug Options
  ids          WIDS debug
  mcast        CAPWAP MCAST Debug Options
  mfp          CAPWAP MFP Debug Options
  rm           CAPWAP RM Debug Options
AP#debug lwapp ?
  client          LWAPP Client Debug Options
  iapp-data-echo  LWAPP IAPP data plane echo
any thoughts?
Cheers
Peter
I managed to find another way of doing it. Details are below
  1. Delete the old flash image file. In my case I had to delete two directories but just assess what files are in flash.
Delete -recursive flash:/<path to directory>
  1. Reload the AP which will make it boot to rommon mode (because there is no flash image to load).
  1. Set the IP Address using the following commands (Case sensitive)
Set IP_ADDR=10.0.0.1
Set IP_SUBNET_MASK=255.255.255.0
  1. Initialize the tftp, ethernet and flash subsystems
tftp_init
ether_init
flash_init
  1. Download the Image using tftp. Use a program like tftpd32.
 tar -xtract tftp://10.0.0.5/ap3g2-k9w7.tar.153-3.JAB.tar flash:
  1. Set type boot image
set BOOT flash:/ap3g2-k9w7-mx.153-3.JAB/ap3g2-k9w7-xx.153-3.JAB
  1. Boot the image
boot
Then my AP booted and I was able to configure it in standalone mode.
Thanks for your help Sebastian. Would still be good to know why I didn't have the debug lwapp console cli or debug capwap console cli commands.....
Reference: https://learningnetwork.cisco.com/thread/60651
Hi Peter,
I'm glad that you have figured it out.
The debug capwap console cli command is hidden and does not show up in IOS help. You just have to write it as it is, hit enter and it will work.
Best regards,
Sebastian
Oh haha, damn knowing that would have saved me some time!
Cheers Sebastian!
